Wienen
Oct 17, 2023Aspirant
R7000 speedcap Xbox Series X over ethernet
I'm having the exact same issue, and we are not alone; https://www.reddit.com/r/xbox/comments/l8u019/xbox_series_x_and_netgear_r7000_ac1900_nighthawk/
I've tried doing a factory reset but unfo...
Oct 18, 2023Guru - Experienced User
Upgrade the router.
- WienenOct 18, 2023Aspirant
I checked on the router update page for a newer version and i got the message this was the latest version (1.0.11.110) based on the forum there is a newer version. I just downloaded it. When i'm at home i will give it a try.
- FURRYe38Oct 18, 2023Guru - Experienced User
đ
- WienenOct 19, 2023Aspirant
I've updated to the latest firmware, and now the problem even got worse đ
Now my download speed droped from 200Mbps to 94Mbps. (Wired) When i connect my xbox directly to my fiber connection, or test at a friends place, the speed gets arround 700Mbps. (same bandwith and provider)
Any ideas?
