mcinturf
Sep 02, 2021Aspirant
R7000 Speedtest slower than ISP ad and direct modem gets, affects all wired and wifi devices
Hi all. First post here...I think. So I purchased this router a few years ago and never got around to setting it up. I'm reasonably good with tech in general but networking is a weak area for me. A f...
- Sep 03, 2021
mcinturf wrote:
Yes, R7000 AC1900. I was wrong in the original post. It is the 8 year old model because it sat in a closet for 3 years after i got it as a gift. And that makes total sense about CTF/...it definitely seems as though its stuck in a permanent QoS on mode. I guess I could try latest firmware, see how it runs and if things are still bad do a reset?---You can try just installing the firmware and seeing how it works. It might still need the reset. Or is that a bad idea?---always worth a shot, worse case is the reset. Like should I immediately update fimware to latest let it reboot and then shut off QoS----yes, try the update and make sure those are off. I'd turn them off first and then update firmware. It it doesn't help, then try the reset. and (all the rest are already off) then go into admin and erase cfg? Ugh. Really not looking forward to getting some of these cameras and lights set up again.---If you use the same ssid/password, they should auto-reconnect. If I use the same SSID and Wifi password most things SHOULD connect. But all the wired devices wouldnt have any problems correct?---Shouldn't. I should mention two of the wired ports do go out to netgear port switches but they are passive and I have never had any problems with them.
Also, since you mentioned it. If i cant get these thing going faster with update and reset, what router would you recommend that is similar that can easily handle 500d/23u and that has the easiest set up features like this R7000 was?----Most of the newer devices should manage those speeds wired (provided they're gigabit and half decent). Wireless is a different matter as those tend to be the device itself that is the limit and not the router. because when I used my original SSID and WiFi pw and settings just about every device reconnected. I had to reset a couple of cameras and lights..and mabye a vacuum. lol. Thanks again.
Sep 02, 2021Guru - Experienced User
You're actually on an older firmware.
the latest is 1.0.11.126
And I know you're against the factory reset, but I'd install the firmware and then do a factory reset.
during the install, leave qos, access control, traffic monitoring, and parental controls all disabled.
They'll slow speeds down.
Also take some speedtest sites with the understanding that they don't always pick the fastest server to test off. Its why we usually recommend people try several sites and different servers on speedtest.
mcinturf
Sep 03, 2021Aspirant
Thanks for the quick response. I actually had the wrong model number, though I suspect they share updates. I was afraid that would be the recommendation. What is interesting is that, in my original post, i was saying that checks through speedtest on the xbox using its own edge browser and through my phone near router wirelessly resulted in very fast speeds 480d, 23u even when the router test in QoS was reporting 250 and 22. That is no longer the case. They all report slower now as well. So I have tried manual values, rebooted, shut it back off, rebooted and now, no matter where I test or how i test nothing goes above 200d. The xbox actually wont download a file over a very consistent 150d with QoS on of off. Its as if there is a bug in the fw that now thinks the QoS is always on no matter what. If that makes sense? I dont recall ever making changes to the settings when this started happening. However, all changes I have made since have only made things worse. And i have only changed ipv6 to auto and QoS to on.. which were originally both off. Now QoS is on again and ipv6 is off and everything is connected and working fine but I do not get speeds over 200 on any device (wired or wireless) but Up is usually accurate at around 20. that being said, all things do work and 200d and 20u is by no means horrible. Its just that I pay for 400d and will get 500d and 23u everytime when a device is connected directly to modem.
So, If i go the update/rest route, should I use the most current or should i revert back to a more stable version? And what is the proper order? If I update firmware and do a reset, will the factory state of the router still be on the firmware i used prior to reset? I believe when I initially installed the device it notified me that it needed an update and picked the 1.09...88 update. in any case I have dl 2 separate versions, the newest you mentioned and an older 1.09...42. It seems people have mentioned that older as being the last stable version. But this is really out of my area of expertise so thank you much for the assistance.
- plemansSep 03, 2021Guru - Experienced User
Do you have the R7000? or the R7000P?
If you have the R7000, try installing the 1.0.11.126, then do the factory reset.
Factory reset only clears out settings. It doesn't change firmware. We recommend the reset just because old settings can cause issues.
also, the R7000 is a 8 year old router. It was top of the line when it came out but it still needed certain things (cut through forwarding) to hit 200+ speeds.
And those features get disabled when qos, access control, traffic monitoring, and parental controls are on. And sadly, sometimes even if you disable those services, it doesn't re-enable CTF.
- mcinturfSep 03, 2021Aspirant
Yes, R7000 AC1900. I was wrong in the original post. It is the 8 year old model because it sat in a closet for 3 years after i got it as a gift. And that makes total sense about CTF/...it definitely seems as though its stuck in a permanent QoS on mode. I guess I could try latest firmware, see how it runs and if things are still bad do a reset? Or is that a bad idea? Like should I immediately update fimware to latest let it reboot and then shut off QoS and (all the rest are already off) then go into admin and erase cfg? Ugh. Really not looking forward to getting some of these cameras and lights set up again. If I use the same SSID and Wifi password most things SHOULD connect. But all the wired devices wouldnt have any problems correct? I should mention two of the wired ports do go out to netgear port switches but they are passive and I have never had any problems with them.
Also, since you mentioned it. If i cant get these thing going faster with update and reset, what router would you recommend that is similar that can easily handle 500d/23u and that has the easiest set up features like this R7000 was? because when I used my original SSID and WiFi pw and settings just about every device reconnected. I had to reset a couple of cameras and lights..and mabye a vacuum. lol. Thanks again.
- michaelkenwardSep 03, 2021Guru - Experienced User
No.
Please do not try installing firmware for the R7000 on an R7000P. Or vice versa.
The update process should prevent this from happening, but if you somehow succeed you can break the device, possibly permanently.
The R7000 and R7000P may look the same but they actually run on different hardware.
Of course neither of these has anything to do with the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 which you seem to have picked for your model number. That is a USB wifi adapter, as the name suggests.
Yeah, I know. Twice actually. Mine is actually the R7000 AC1900 Smart WiFi ROUTER. Wasnt at home with it during orginal post and accidentally grabbed the wrong one from pulldown the seond time. Its this router. The one thats a few years old. I will try the latest firmware for it.
