wedgef5
Mar 21, 2020Initiate
R7000 spotty 5G performance
I've had a R7000 for a few months now. Initially, everything was pretty good performance-wise. Recently, though, we've started having a problem where some devices on the 5G network have good throughp...
- Mar 21, 2020
The R7000 has had major firmware issues. the agreed upon stable version is the .42 version of the firmware.
downgrade to that over a hardwired connection, factory reset the router afterwards and then manually install. don't install from a a backup configuration.
Try that and see if it helps
Mar 21, 2020Guru - Experienced User
wedgef5
That seems better, at least initially. Thanks for the help!
