wedgef5's avatar
wedgef5
Initiate
Mar 21, 2020
R7000 spotty 5G performance
I've had a R7000 for a few months now. Initially, everything was pretty good performance-wise. Recently, though, we've started having a problem where some devices on the 5G network have good throughp...
  • plemans's avatar
    Mar 21, 2020
    The R7000 has had major firmware issues. the agreed upon stable version is the .42 version of the firmware.
    downgrade to that over a hardwired connection, factory reset the router afterwards and then manually install. don't install from a a backup configuration.
    Try that and see if it helps
