tns's avatar
tns
R7000 stopped accepting wifi connections.(V1.0.11.126)
The router is setup with one wired PC, and wifi just for the guest acct (cell phones, laptops). The non-guest wifi SSID broadcast is disabled, but both the 2.4 and 5G wireless guest bands are fully enabled and use the same wifi password and the automatic/smart band select is on. It all worked fine for a month but then the wifi stopped allowing any device to join the network. The SSID is still being broadcast for both guest bands but attempts to join are refused, even for devices that previously worked. Power cycling does not fix it. The wireless light is on.
I did an ERASE from the GUI (I assume this does the same as Hard Reset button) and setup the router again, but I still get a message like, "you cannot join the network at this time". If I mistype the wifi password I get a bad password message instead, so the problem isn't the password. I also tried reinstalling the same V1.0.11.126 FW, but it didn't help. The next step will be to revert to the older FW.
  • After trying several different setting changes the wifi still refused connections.
    I downgraded the FW to V1.0.11.110, performed an ERASE, manually reconfigured, and the wifi is working normally again.
    I'll post if it fails again.
    • michaelkenward's avatar
      michaelkenward
      tns wrote:
      ..performed an ERASE,
      That isn't a term that I recognise. Is it what Netgear calls a factory reset?
      • tns's avatar
        tns
        The user manual describes both the hard button reset, and the ERASE function in the GUI (under advanced->backup), as a return to factory settings. If there is any difference, I'd like to know. This router is in the attic, so using the hard reset is a chore.
