mtim2000
Nov 30, 2017Follower
R7000 stopped connecting to an ISP via PPPoE
hello everyone, I am having issues with R7000, which I can't resolve for last two days. The setup I had for last two years, without any issues, is as follows: VDSL Modem SmartRG SR505N (in bri...
- Apr 30, 2018
Hi vamsibannu,
What is the firmware version of the router?
https://kb.netgear.com/000055563/R7000-Firmware-Version-1-0-9-28
vamsibannu
Mar 29, 2018Aspirant
I am facing the very similar problem and when i contacted customet care they simply said they cant do much as the hardware is working and asked me to check with my ISP provider. But i tried my friend's cisco and tplink routers. Both worked in a flash. I have been trying to fix my netgear r7000, but no luck. Very disappointing.
michaelkenward
Mar 29, 2018Guru - Experienced User
You've tried to factory reset thing?
- vamsibannuApr 28, 2018Aspirant
Hi,
Yeah i did try hardware reset and reconfiguring the router. Still the problm is not solved.
Sometimes it connects and if I switch the power off and switch it on again, it doesn't connect.
Anyone one from netgear recommend a specific firmware version or may be beta version to this issue resolved.
I am asking so bcoz, i read in the community that it worked for someone.
- michaelkenwardApr 28, 2018Guru - Experienced User
.... and the startup sequence?
Yeah i did try the whole sequence from step 1, still no luck.
