JimJoat
Dec 29, 2017Aspirant
R7000 Stops Connecting to the Internet
>>Recently, and sporadically I cannot do a standard connection to the Internet via web browsers using Window PCs or Android smart phones. >>I also cannot login to the router at 192.168.1.1 (no res...
- May 19, 2018
To close out this thread!
- I purchased a R7000P Netgear Nighthawk AC2300. It crashed on my LAN as well, and I returned it.
- I then connected up my old Netgear WNR3500L V2 -- Flashed with Tomato-Shibby -- and it worked fine for the two weeks I had it connected.
- I have now flashed my R7000 router with Tomato-Shibby "tomato-R7000-ARM--132-AIO-64K".
- This has stopped the router from crashing. It has been more than 3 weeks without any problems.
- The fact that the R7000 and R7000P both crashed tells me that base firmware has an issue.
- I'll stick with Tomato, but will really have to think hard about what my next router purchase will be!
TheEther
Dec 30, 2017Guru
There have been a lot of complaints about V1.0.9.18_1.2.27. I think Netgear is working on new firmware. You might want to downgrade to an older version until it's ready.
