Cfr5
Jun 28, 2021Aspirant
R7000 Stops Working
My R7000 has recently stopped working randomly in the day. It is progressively getting more frequent and affects both wireless and wired devices. It has been about once a week, then once a day, now it...
Cfr5
Jul 12, 2021Aspirant
Sorry for the delayed response.
1) it is the R7000
2) Current firmware is V1.0.11.106_10.2.100
3) It’s attached to Netgear CM1000 modem.
Thanks for the help.
1) it is the R7000
Jul 12, 2021Guru - Experienced User
Try manually installing the latest 1.0.11.123 version.
Then do a factory reset and a reinstall.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
