BenZ
Sep 14, 2016Aspirant
R7000: streaming mp3 from hd ( USB connected on router )
Google's Chromecast Audio is properly working for streaming music (mp3) from my smartphone to my stereo emplifier . However streaming mp3's stored on a HD attached via USB to my R7000 router is not ...
- Oct 03, 2016
It may be better off to get a NAS most especially if you have big files.
How big is the external hard drive?
ElaineM
Sep 22, 2016NETGEAR Employee Retired
Do you have the latest firmware installed?
I have tried this from my iPhone and it's fine.
I wonder if it's an Android thing. What's the OS of your S5?
BenZ
Sep 22, 2016Aspirant
My Samsung Galaxy has Android 6.01 OS.
I believe It has something to do with my router settings:
I can make back-ups of my Computer HD (Surface pro 10, Windows) and a USB HD connected to my router to a second (back-up) HD also connected to my router. This is running smootly!
However when I touch the R7000 logo (Netgear Genie) on my Android smart phone the 'app' isn't able to collect data from R7000's usb drives. (renewing source map and restarting media-service doesn't has any effect
I just started Netgear Genie on my windows 10 PC and I got the following:
System doesn't exist..........
Still confusing me
Regards
- ElaineMSep 23, 2016NETGEAR Employee Retired
Let me try to replicate it from my end.
- ElaineMSep 28, 2016NETGEAR Employee Retired
No problems on the Android.
Can you try to use a thumb drive for the mean time and see if that will be read?
If the same thing happens, I suggest that you factory reset the router then reconfigure it.
