MBG0707
Mar 03, 2018Aspirant
R7000 stuttering internet connection, keeps disconnnecting
I've had the Nighthawk r7000 router for three months without any issue for recalling. The past couple weeks however, my connection has been hiccuping. I mean that the router will stop connection of a...
- Mar 11, 2018Looked into the Intel Puma chipset ordeal and what I saw suggested that the problem I’m experiencing is comparable to what occurs in affected modems. So I bought a new one, it’s been a week and no problems.
Thank you for everyone’s help!
MBG0707
Did not know that about the channels. I'll change it.
My modem is on the list, I will look into the chipset issue and see if the problems it is known for are related and replace it. Is there a suggested modem approved by Spectrum I should lean towards?
The router does allow adjusting the radio power output, but I have to type out a numerical value, there isnt a High Med Low option. There is the Fragmentation length (236-2346) and the CTS/RTS Threshold (1-2347). Both are set currently at highest, 2346 and 2347 respectively. Should I enter the halfway values? Or maybe a bit above?
MBG0707
Mar 11, 2018Aspirant
