Merlin_309
Jul 21, 2020Tutor
R7000 Sudden Death - radio lights out; ethernet ports all red/purple, can't reset, no HTTP response.
Disappointing. After only 4 years my Nighthawk R7000 died suddenly. The reset button is inoperative. I can't connect to it using an ethernet cable connected to an isolated computer. Both the 2.4 ...
- Jul 30, 2020
Sorry. You're probably SOL then.
Merlin_309
Jul 29, 2020Tutor
Good idea - - but no luck with an alternate power suppy.
Jul 30, 2020Guru - Experienced User
- Merlin_309Jul 30, 2020Tutor
Yep - - Replacement already in place.
Linksys MR8300- plemansJul 31, 2020Guru - Experienced UserHope it treats you well! I've had a couple linksys routers and they worked well for the most part
