wwooten64
Oct 05, 2024Follower
R7000 suddenly not working with Ecobee
i have a R7000 Nighthawk for over 4 years and an Ecobee smart thermostat that has been connected for over 2 years and suddenly, it connects to router but it won't connect to ecobee server. Ecobee sup...
Oct 06, 2024Guru - Experienced User
If it has been working with the R7000, something may have change at the ISP level or Eecobee level. Doesn't mean the NH router did something unless someone changed something on the router.
Had you been using Smart Parental controls or Armor?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Make contact with Ecobee regarding there product for help and information as well.
