benjman25
Jan 15, 2021Aspirant
R7000 Suddenly Won't Access Certain Sites
I have had an R7000 for a little over three years, and haven't had an issue until this past week. With the new year, my work benefits reset, and I have been trying to login to the Express Scripts we...
Jan 15, 2021Guru - Experienced User
What modem/gateway is it connected to?
Have you tried using googles dns (8.8.8.8 or 8.8.4.4) or cloudfares at 1.1.1.1?
- benjman25Jan 15, 2021Aspirant
Hi plemans, thanks for your response. I'm unable to tell exactly what it's plugged into; internet is provided through my condo building, so the entire building is wired with the same ISP and it's paid through the monthly dues.
Yes, I did try Google's dns, no change.
