Dustin_V
Feb 25, 2020NETGEAR Employee Retired
R7000 Support, Info & Firmware #EPIC Article
Visit this #Epic article for the latest support, product info and firmware support for the AC1900 WiFi Router (R7000). R7000 is an 802.11ac (WiFi 5) dual band router, supporting AC1900 (600+1...
bkds
Feb 27, 2020Tutor
This router is complete garbage. I "upgraded" from an N600 which quit working to the R7000. Issues right out of the box with 5ghz wifi. Tried reseting, downloading different firmwares from netgear, and even went to third party firmware. I just recycled your POS product that lacked reliability after dealing with its BS for over a year at the same bestbuy I bought it from and walked out with an Asus. For anyone looking to jump on the discounts for this model do yourself a favor and pass. Spend a little more or less with someone else.
MaiMariarti
Apr 26, 2020Initiate
Horrible firmware.
So many bugs. So unreliable! So expensive for a piece of junk.
Upgraded the firmware up and down. Every version is worse then before.
If you enjoy pulling your hair out, or have your wifi keep dropping on you, then buy this router.
