Dustin_V
Feb 25, 2020NETGEAR Employee Retired
R7000 Support, Info & Firmware #EPIC Article
Visit this #Epic article for the latest support, product info and firmware support for the AC1900 WiFi Router (R7000). R7000 is an 802.11ac (WiFi 5) dual band router, supporting AC1900 (600+1...
jmac44
May 09, 2020Initiate
I have been having issues with using my older router WNDR3700v3 with Nighthawk R7000. is there some compatability list for the nighthawk app and connections between other Netgear products, For the Nighthawk router? I am running Win 10 have google nest camera and a/c honeywell the camera is connected to the wndr3700 and constantly losses connection and i need to reboot both nighthawk and older router to complete connection again.all firmware on both devices has been updated.
- antinodeMay 09, 2020Guru
> Nighthawk R7000. [...]First, start your own thread for your own problem, instead of
diverting this existing sales-promotion/user-rant thread from its
original "purpose".When you do that, it might help if you explained why you're trying to
use two routers, and how, exactly, you've connected your stuff. (Hint:
If a device has different types of Ethernet ports, then "connected to
device" is not enough detail.)- jmac44Sep 23, 2020InitiateLet me tell you first about attitude, whoever you are. Sorry I did not get the right forum tolic/etc..,etc! If this is netgears tech help you should learn how to effectively communicate a little better than belittling people and how they use forums. So far this community has had n I thing to say except smart ass remarks that really make people not want to come back and are very unprofessional about being part of such a large company.
- sktn77aSep 24, 2020Virtuoso
Well, I haven't had any problems with multiple R7000s (within their operating parameters). That said, I've never updated the firmware above v1.0.9.42_10.2.44. Now, Netgear "technical Support" (or any support from this company) is pretty non existant, so if you do have a problem, you're on your own.
