Dustin_V
Feb 25, 2020NETGEAR Employee Retired
R7000 Support, Info & Firmware #EPIC Article
Visit this #Epic article for the latest support, product info and firmware support for the AC1900 WiFi Router (R7000). R7000 is an 802.11ac (WiFi 5) dual band router, supporting AC1900 (600+1...
bkds
Feb 27, 2020Tutor
This router is complete garbage. I "upgraded" from an N600 which quit working to the R7000. Issues right out of the box with 5ghz wifi. Tried reseting, downloading different firmwares from netgear, and even went to third party firmware. I just recycled your POS product that lacked reliability after dealing with its BS for over a year at the same bestbuy I bought it from and walked out with an Asus. For anyone looking to jump on the discounts for this model do yourself a favor and pass. Spend a little more or less with someone else.
RicanPradaG
Jun 08, 2020Initiate
I can't agree with you more! This router is straight Sh**. My wifi goes out all the time. Ive reset/rebooted/wiped/erase all forms of technical support. It is sad to say my $10 a month router from Spectrum ran so much better than this device and I spend 150. Lately its been giving me more issues. the 5GHZ drops all the time. My gaming PC not getting internet intermittently, even though its on ethernet.
- davemaysJun 08, 2020Guide
I still have mine hooked up to a simple digital timer that turns the power off and back on every week. It's the only way I could make this device "reliable" enough.
Why Netgear won't put in a scheduled reboot feature is beyond me. The device clearly needs one.
