Dustin_V
Feb 25, 2020NETGEAR Employee Retired
R7000 Support, Info & Firmware #EPIC Article
Visit this #Epic article for the latest support, product info and firmware support for the AC1900 WiFi Router (R7000). R7000 is an 802.11ac (WiFi 5) dual band router, supporting AC1900 (600+1...
Wagneld
Sep 05, 2020Aspirant
This router is worthless gets disconected several times a day, it's frustrating trying to figure out into the router's setup how to stop having this issue. I decided to change netgear for an ASUS router and I haven't had any issue.
labatt
Sep 05, 2020Mentor
Went a different route from you, but with the same no problems after the move. I went to more commercial side. Glad I did as you are.
