Dustin_V
Feb 25, 2020NETGEAR Employee Retired
R7000 Support, Info & Firmware #EPIC Article
Visit this #Epic article for the latest support, product info and firmware support for the AC1900 WiFi Router (R7000). R7000 is an 802.11ac (WiFi 5) dual band router, supporting AC1900 (600+1...
Matt22
Aug 16, 2021Aspirant
I purchased Netgear's Nighthawl R7000 just in May 2020. This device started dropping internet few Months after purchase, right after the 90 days support is over. The phone app is telling me the firmware is up to date but online their website is showing a different firmware. I called the tech support who is asking me to buy technical support without telling me what’s wrong with the devise. This is fairly new device. Not 5 years old or no longer supported. In fact, they are still selling the same device people and others are having the same issue after their 90 days. If it was a defect on this particular device then why others are having the same issue? And, why one have to pay to fix it if it’s a defect? It’s obvious it was set up this way.
Other customers said ‘’the technical support from Netgear is pathetic, unprofessional and fraud. Their team has only one motive: to sell extended warranty (beyond 90 days) and dupe customers. They purposefully create issues and when customers call for help, they force them to buy 3m/6m/1year support at extra cost and fix the issue. This is their game plan and any amount of escalations makes no difference. Sincere advice: avoid buying their products and tech support.’’ This is true and honest statement. I myself regret buying from Netgear and would not recommend anyone falling in the same trap. Call them and check reviews to confirm it yourself.
