Marchelloh
May 21, 2022Initiate
R7000 tends to crash after updating to IPv6 and changing ISP modem to Ubee UBC1318ZG
Hi all, I still have an older Netgear router up&running, the R7000. A few months ago, my internetsupplier (Ziggo in Netherlands) informed me that i could finally upgrade to IPv6, but I had to tak...
- May 21, 2022
1. you're not on the latest version of firmware. the Current right now is 1.0.11.134
2. not all ISP devices run fine in bridge mode. Try leaving the ubee in router mode (disabling its wifi) and either put the netgear's ip address into the Ubee's DMZ or put the netgear in access point mode.
May 21, 2022Guru - Experienced User
Marchelloh
May 27, 2022Initiate
Thanks!
I always checked for new firmware through via the check delivered with the R7000 software, that showed that i was on latest firmware. I have now updated the software. If the crashing continues, I will get my Ubee out of bridge mode.
- plemansMay 28, 2022Guru - Experienced User
Good luck! let me know how it goes
