Nicce70
Mar 08, 2016Aspirant
R7000 Time and date is wrong
My new R7000 is showing wrong time and date, and I cant change it. I have tried reset to default, turned it off for some time, upgraded the FW, but nothing helps. It starts showing the time and dat...
- Mar 21, 2016
You know what, I got it to work!!
Instead of letting R7000 getting the primary and secondary DNS from the ISP automaticly, I set them manually, and wips it did work!
Retired_Member
Mar 08, 2016The router needs a internet connection to update the date and time. Can you surf web with it? Try a reboot from the advanced home menu. Try rebooting modem then router.
- Nicce70Mar 08, 2016Aspirant
I have internet connection, everything works fine, except for the date and time.
Tryed reboot from advance home menu and modem, but its the same, it starts date and time counting from 2003 1 jan 00:00.00.
- Retired_MemberMar 08, 2016
Contact Support or return/exchange it.
- JamesGLMar 09, 2016NETGEAR Employee Retired
Hi Nicce70,
I have sent you a message. Please check your inbox.
