Nicce70
Mar 08, 2016Aspirant
R7000 Time and date is wrong
My new R7000 is showing wrong time and date, and I cant change it. I have tried reset to default, turned it off for some time, upgraded the FW, but nothing helps. It starts showing the time and dat...
- Mar 21, 2016
You know what, I got it to work!!
Instead of letting R7000 getting the primary and secondary DNS from the ISP automaticly, I set them manually, and wips it did work!
Nicce70
Mar 21, 2016Aspirant
I got a reply from my ISP, and they saying that my connections router (not mine) doesn't support NTP.
So I guess I have to live with this problem, unless Netgear make an option in the firmware to retreive the correct date and time to the router.
Nicce70
