IrvSp
Nov 18, 2017Master
R7000 time synch repeating often all of a sudden?
This started a day or two ago. =========== [Time synchronized with NTP server] Saturday, Nov 18,2017 06:22:06 . [Time synchronized with NTP server] Saturday, Nov 18,2017 04:59:15 . [Time syn...
- Nov 22, 2017
Hi IrvSp,
If you reboot both router and the modem, will it have the same problem?
JamesGL
Nov 22, 2017NETGEAR Employee Retired
Hi IrvSp,
IrvSp
Nov 27, 2017Master
JamesGL, I've tried these after the ISP replaced the modem and the problem remained:
- Going back a release of the F/W
- Ensured the settings were correct (they were)
- Checking after a few hours... still had the problem
- Did the 30-30-30 Reset.
- The router DID not really reset? That is the settings were retained?
- Went back to the latest release and followed the above steps again
Aren't the settings supposed to be wiped out with the 30-30-30 reset? I KNOW I've done it before and they have been? One easy way for me to tell is that I set the lights to be OFF, only the Power on. That doesn't change after the reset nor do any settings? This is on the V1.0.9.12_1.2.23 firmware.
Also I discovered something 'odd' on the Connection Status on the Advanced Tab.
| Connection Status |
| IP Address | 67.xx.xx.xx |
| Subnet Mask | 255.255.248.0 |
| Default Gateway | 67.xx.xx.xx |
| DHCP Server | 10.120.0.1 |
| DNS Server | 75.114.81.1 209.18.47.62 75.114.81.2 |
| Lease Obtained | 0 days,1 Hours,52 Minutes |
| Lease Expires | 0 days,1 Hours,44 Minutes |
What goes with that LEASE data? Who is doing this? The router only asking for a limited time or my ISP on providing limited time? I'd think that would explain the TIME SYNC's as the lines I've deleted shows the IP Address the router got from the ISP... consistent with the Lease renewal? Also, I've tried the 30-30-30 a few times and that Lease time changes on each reset, low of 1 hour and 20 minutes to a high as shown above.
Is this a FLASH problem? Router problem? ISP problem?
The new Modem is getting time at a completely difference schedule as well it seems:
| 11/25/2017 23:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 2:42 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 3:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 6:42 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 7:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 9:42 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 10:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 12:42 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 13:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 15:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 16:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 17:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 18:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 19:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 21:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 22:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/26/2017 23:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/27/2017 0:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/27/2017 1:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/27/2017 3:43 | 4000960006 | New time has been retrieved from ToD server. |
| 11/27/2017 6:43 | 4000960006 | New time has been retrieved from ToD server. |
Heck, nothing is working even as we're asleep. NOTE they all end with :43 too?
Have any idea what is going on? Has my router failed in some way or should I be 'looking' at my ISP?
