dobb823
Sep 09, 2021Aspirant
R7000 Trying to Connec to to Office L2TP VPN
Hi, Just put in the R7000 running on the Firmware V1.0.11.116_10.2.100 and struggling to get it to connect to a VPN that is running AS L2TP/IPsec with pre-shared key. Now this all worked prio...
dobb823
Hey there,
Not 100% sure but it looks like this and was installed by open reach
dobb823
- dobb823Sep 09, 2021Aspirant
sorry note sure why this image isnt working
- FURRYe38Sep 09, 2021Guru - Experienced User
Ok, checking for a router at the modem/ONT point. Your ok there.
When you configured port fowarding, did you disable uPnP on the router?Any of this help?
https://kb.netgear.com/966/Troubleshooting-VPN-passthrough-for-home-routers
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Ports-for-L2TP-VPN/td-p/1223802
Thanks for coming back to me. I had not turned that off. I have turned that off but to no avail.
I have followed those 2 x links multiple times to also to no avail.
My port forwarding looks like this
