dobb823
Sep 09, 2021Aspirant
R7000 Trying to Connec to to Office L2TP VPN
Hi, Just put in the R7000 running on the Firmware V1.0.11.116_10.2.100 and struggling to get it to connect to a VPN that is running AS L2TP/IPsec with pre-shared key. Now this all worked prio...
michaelkenward
Sep 10, 2021Guru - Experienced User
Portwey84 wrote:
I'm afraid my own experience of Netgear's firmware release program, is that it isn't in my opinon, the best.
Oh so true.
To add to the saga, the automated check routine is a poor guide because new firmware comes in various stages through different channels.
Beta versions can go out to chosen people who don't mind taking their life in their hands.
Next, if the beta is acceptable, comes a "hotfix", a new release that has yet to go through all the quality checks, for what they are worth.
Finally, there is a new release. But that too has a couple of release channels. Usually it appears, as Portwey84 says, on the support pages. Then it goes to the update server that feeds the "check for updates" feature.
However you get a new version, experienced users have witnessed enough grief to avoid anything but a manual update.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You probably didn't want to know all of that.
dobb823
Sep 14, 2021Aspirant
This randomly just started working for 4 days ...
Hard turned off Router last night, turned it back on ... not working again .... ffs
