Miles49
Mar 30, 2020Aspirant
R7000_UM.pdf
I have tried to download the router's newest user manual several times over several days and each time Adobe reports that the file is corrupted. I want the new user manual because my manual tells me...
- Mar 30, 2020
Miles49, I am able to successfully download the User Manual for the Nighthawk AC1900 Smart WiFi Router (Model R7000) from here. The document is dated January, 2019 (186 pages). Perhaps you can try the download using a different PC?
P.S.: It is unclear how the router's built-in firmware update process would destroy the device.
Topology
Mar 30, 2020Virtuoso
- Miles49Mar 30, 2020Aspirant
I was able to down load the user manual on another computer, actually a tablet.
I don't know definitively how the update function destroyed of the older R7000 router either. All I know is that after updating the router firmware it would not longer function. I couldn't even log into it. I contacted NetGear customer service and spent aboout four hours with them trying to recover the router to no avail. The IT person told me it was dead, not recoverable and, since it was out of warranty, I would have to buy a new one. He said that most likely the update was corrupted during download and a non-functioning router was the result. I did buy a new one and have been very reluctant to update the firmware.
- michaelkenwardMar 31, 2020Guru - Experienced User
What did the LEDs on the thing look like?
If the power LED was not as expected, flashing or amber, then there may still be ways to bring it back to life. Many many people have done so.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
I hope you didn't not phone someone on the basis of a web search.
If you called a number that you found with a web search, that almost certainly had nothing to do with Netgear.
Netgear handles paid for support through GearHead Technical Support.
Web searches can deliver results that scream "Netgear support" at the top but that turn out to be anything but. Using them can be dangerous, for your network and your bank balance.
Sounds like someone who didn't know what they were talking about.
The most reliable way to update the firmware is to follow the manual approach with a wired connection to the router. The manual explains how to go about that.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- Miles49Mar 31, 2020Aspirant
I called NetGear Support directly and if I reached someone who wasn't qualified, it is not my fault but NetGear's. Anyway the Power LED was steady white but the computer could not communicate with the Router. We tried what you proposed to upload the firware, but the router would not respond. The other lights should that devices were attached, but the router would not respond to the other devices. Three or four hours of finageling and attempting other recovery methods more than likely exhausted the list of repairs. The IT services engineer with whom I was communicating also talked with several other engineers and technicians and all were stumped. The old router has been disposed by recycling. I no longer have possession. I still have tepidation concerning updating the firmware in this unit. After all, having to spend about $400 in three years to end up with one quality router is alittle more than my budget could take.
