GumboKen's avatar
GumboKen
R7000 Unable to save to USB after updating to ver. 1.0.12.216
After updating to version 1.0.12.216 I am unable to save to the \\readyshare USB.  I can read from it, but I cannot save to it.  Previously when I would have problems with just generally accessing th...
  • GumboKen's avatar
    Nov 26, 2024
    After searching and reading general problems similar to this, I believe the problem is due to the size of the file I was trying to transfer.  One comment said that doing a transfer across their network seems to have a problem when the file size is around 2GB; the file I wanted to transfer is 1.8GB.  I have transferred a group of files that totaled much larger than 2GB, but I don't believe I've ever tried to transfer a single file this large before.
    So I just removed the USB stick, copied the file to it, and reinserted it into the router.
