Baker_Street
Jan 24, 2023Aspirant
R7000 unstable after update to V1.0.11.136_10.2.120
Good evening all- I have recently updated the firmware on my Nighthawk R7000 to the current download: V1.0.11.136_10.2.120 . Now I am having to reboot the router multiple times each day! Before th...
- Jan 25, 2023
Baker_Street wrote:
Now I am having to reboot the router multiple times each day! Before the the update, I hadn't had to reboot for more than 4 months. I need some help getting some stability in the WiFi.
The first thing to try after you have issues with new firmware is the dreaded reset.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
michaelkenward
Jan 25, 2023Guru - Experienced User
Baker_Street
Jan 25, 2023Aspirant
Thank you. I'll give that a go and let you know after a couple of days what the result is. 🙂
Is there any difference between pushing the reset button and using the command under backup settings in the advanced router settings "revert to factory settings?" I'll use the button today.
- michaelkenwardJan 26, 2023Guru - Experienced User
Not really. I find that the router settings ensures that it work. The button can be picky about the timing.
Just keep your eye on the router's LEDs for signs that it is rebooting.
- Baker_StreetJan 26, 2023Aspirant
So far, so good. It has been a whole day with no reset necessary. Woo-Hoo! I have my fingers crossed that it remains stable.
- FURRYe38Jan 26, 2023Guru - Experienced User
Enjoy. 📡
