slapi2000
Jan 08, 2016Aspirant
R7000: UPNP Renderer not visible when connected via WiFi
Hi all, I use the R7000 as a router and have the problem that my UPNP renderer (Denon DNP-F109) is not visible if connected via WiFi (via Ethernet, everything works fine). Can anybody give me a ...
- Jan 11, 2016
Hi Stefan,
Please perform a reset on the device and check again if still the same problem.
JamesGL
Jan 10, 2016NETGEAR Employee Retired
Hi Slapi2000,
What is the IP address of your renderer?
Can you ping the IP address?
Do you have other devices working with wireless?
What is the firmware version of the router?
- slapi2000Jan 10, 2016Aspirant
Hi,
IP address: 192.168.1.2 (static assignment)
Ping: yes
Other devices: yes, few mobile phones/tablets (none of which with any UPNP role).
Firmware: V1.0.6.28_1.1.83 (the bug is there since a number of releases - I have been hoping since a while this gets fixed at some point)Best regards,
Stefan- JamesGLJan 11, 2016NETGEAR Employee Retired
Hi Stefan,
- Retired_MemberJan 11, 2016
Have you tried address reservations?
