slapi2000's avatar
slapi2000
R7000: UPNP Renderer not visible when connected via WiFi
Hi all,   I use the R7000 as a router and have the problem that my UPNP renderer (Denon DNP-F109) is not visible if connected via WiFi (via Ethernet, everything works fine). Can anybody give me a ...
  • JamesGL's avatar
    JamesGL
    Jan 11, 2016
    Hi Stefan,
    Please perform a reset on the device and check again if still the same problem.
