slapi2000
Jan 08, 2016Aspirant
R7000: UPNP Renderer not visible when connected via WiFi
Hi all, I use the R7000 as a router and have the problem that my UPNP renderer (Denon DNP-F109) is not visible if connected via WiFi (via Ethernet, everything works fine). Can anybody give me a ...
- Jan 11, 2016
Hi Stefan,
Please perform a reset on the device and check again if still the same problem.
slapi2000
Jan 10, 2016Aspirant
Hi,
IP address: 192.168.1.2 (static assignment)
Ping: yes
Other devices: yes, few mobile phones/tablets (none of which with any UPNP role).
Firmware: V1.0.6.28_1.1.83 (the bug is there since a number of releases - I have been hoping since a while this gets fixed at some point)
Best regards,
Stefan
JamesGL
Jan 11, 2016NETGEAR Employee Retired
Hi Stefan,
- Retired_MemberJan 11, 2016
Have you tried address reservations?
- slapi2000Feb 06, 2016Aspirant
Hi,
having tested for a while, I can confirm that the router reset did solve the issue. Many thanks for the hint.
Best regards,
Stefan
- JamesGLFeb 08, 2016NETGEAR Employee Retired
Hi slapi2000,
Glad to know it works now.
