millerre1959
Apr 26, 2016Star
R7000 USB ports not working properly
I decided to use small form factor USB 3.0 and USB 2.0 flash drives for my ReadyCLOUD account on my Netgear R7000. Here is the outcome of my installation: -- USB 2.0 drive works in both USB ports ...
- May 06, 2016
The beta firmware fixed the problem. Many thanks!
LEyTyHE
Apr 26, 2016Aspirant
For me, the problem is when I use both USB 3.0 and USB 2.0 flash drives for my ReadyCLOUD, it only shows the device attached to the USB 2.0 port. Meanwhile, the FTP service works fine as the two drivers shown properly. I don't know the problem happens due to whether my setting or the firmware bug.
R7000, BETA firmware 1.0.5.60
JamesGL
Apr 28, 2016NETGEAR Employee Retired
Hi All,
If both of you used already the beta version v1.0.5.60, please try the 2nd beta firmware below. Reset the router after the update and manually reconfigure.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-62/m-p/1078114#U1078114
- millerre1959Apr 29, 2016Star
The router firmware I have used since the beginning is V1.0.6.28_1.1.83. Are you suggesting that I downgrade?
- JamesGLMay 01, 2016NETGEAR Employee Retired
Hi millerre1959,
The firmware v1.0.6.28 has been pulled out from support site due to some reported issues. I would suggest using the beta firmware.
- millerre1959May 06, 2016Star
