millerre1959
Apr 26, 2016Star
R7000 USB ports not working properly
I decided to use small form factor USB 3.0 and USB 2.0 flash drives for my ReadyCLOUD account on my Netgear R7000. Here is the outcome of my installation: -- USB 2.0 drive works in both USB ports ...
- May 06, 2016
The beta firmware fixed the problem. Many thanks!
JamesGL
May 01, 2016NETGEAR Employee Retired
Hi millerre1959,
The firmware v1.0.6.28 has been pulled out from support site due to some reported issues. I would suggest using the beta firmware.
millerre1959
May 06, 2016Star
