millerre1959
Apr 26, 2016Star
R7000 USB ports not working properly
I decided to use small form factor USB 3.0 and USB 2.0 flash drives for my ReadyCLOUD account on my Netgear R7000. Here is the outcome of my installation: -- USB 2.0 drive works in both USB ports ...
- May 06, 2016
The beta firmware fixed the problem. Many thanks!
Texxen
Jul 27, 2016Aspirant
This seems to be a never ending problem. R7000 USB 3.0 port. Had 1.0.5.70 firmware. Updated to 1.0.6.40 firmware. Now have 1.0.6.54 firmware. Same story USB 3.0 shows up,works until I reboot router. Have a SanDisk Ultra Fit 64gb. USB 2.0 works all the time. It's a repeat of everything I've read everywhere else. Are the Asus routers working properly (AC1900 series)???
