millerre1959
Apr 26, 2016Star
R7000 USB ports not working properly
I decided to use small form factor USB 3.0 and USB 2.0 flash drives for my ReadyCLOUD account on my Netgear R7000. Here is the outcome of my installation: -- USB 2.0 drive works in both USB ports ...
- May 06, 2016
The beta firmware fixed the problem. Many thanks!
JamesGL
Jul 27, 2016NETGEAR Employee Retired
Hi Texxen,
Have you tried to reset the router after updating the firmware? If not yet, please try to reset it and manually reconfigure the device.
Texxen
Jul 28, 2016Aspirant
Yes, reset router, no USB 3.0. (SanDisk ultrafit 64gb, NTFS format,2 partions) Works in USB 2.0
