millerre1959
Apr 26, 2016Star
R7000 USB ports not working properly
I decided to use small form factor USB 3.0 and USB 2.0 flash drives for my ReadyCLOUD account on my Netgear R7000. Here is the outcome of my installation: -- USB 2.0 drive works in both USB ports ...
- May 06, 2016
The beta firmware fixed the problem. Many thanks!
roorats
Aug 05, 2016Tutor
I am still on my 1st unit, have not unboxed the 2nd because I need to know for certain my issue doesn't apply to all R7000 units.
My first question, after finding some info on this topic, is it true that not ALL external hard drives may be compatible with the router?
Last night I purchased a new LaCie 1TB USB 3.0 ext hd and plugged it into the router which to my surprise worked fine in the 3.0 port?? I was able to transfer and view on ready cloud instantly. There was some lag albeit but it worked. However my WD MyBook 5TB is a hit or miss with constant issues. Any thoughts here?
