Swiftrunbob's avatar
Apr 01, 2019
R7000 Use second one in AP mode or Use Wireless Extender Instead?
Hi currently I have my R7000 in my dining room.  Its wired to a living room TV, PVR and a bedroom TV & PVR. When Im in my bedroom my wifi signal is poor.  I was thinking of adding a 2nd R7000 int...
  • michaelkenward's avatar
    michaelkenward
    Apr 02, 2019
    Swiftrunbob wrote:
    I’ve used an extender in another situation and they are just never fast enough.
    That doesn't make sense. An extender can be either wired to a router as an Access Point or "bridged" as a wifi repeater.
    It is hard to see how an extender in AP mode can be slower than a router in AP mode.
    The router would certainly be more expensive.
    Swiftrunbob wrote:
    I’m just not sure if it should be setup as a wired bridge, wired AP or a wired repeater.
    What's the difference?
    AP mode is probably the easiest.
