Swiftrunbob
Apr 01, 2019Tutor
R7000 Use second one in AP mode or Use Wireless Extender Instead?
Hi
currently I have my R7000 in my dining room. Its wired to a living room TV, PVR and a bedroom TV & PVR.
When Im in my bedroom my wifi signal is poor. I was thinking of adding a 2nd R7000 int...
- Apr 02, 2019
Swiftrunbob wrote:
I’ve used an extender in another situation and they are just never fast enough.That doesn't make sense. An extender can be either wired to a router as an Access Point or "bridged" as a wifi repeater.
It is hard to see how an extender in AP mode can be slower than a router in AP mode.
The router would certainly be more expensive.
Swiftrunbob wrote:
I’m just not sure if it should be setup as a wired bridge, wired AP or a wired repeater.What's the difference?
AP mode is probably the easiest.
michaelkenward
Apr 02, 2019Guru - Experienced User
Swiftrunbob
Apr 02, 2019Tutor
Hi
I used the extender wirelessly, a wired extender probably would have worked better.
I’ll try setting up the 2nd R7000 as an AP
Thanks👍🏼
Thanks👍🏼
