JJ77
Sep 17, 2017Tutor
R7000 using USB readyshare for backups
I have a WD 8T external drive plugged into the router USB port. All pc's can see the drive through readyshare. Can you safely use the drive through ready share to backup the pc's?? All pcs and table...
- Sep 18, 2017
ReadyShare is a part of your LAN. It shows up in the Network in Windows. Unless you have done something to make these drives available on the internet, no one out there is going to be able to access your files.
michaelkenward
Sep 18, 2017Guru - Experienced User
What's the question?
If the PCs can see the USB drive you can certainly backup to them. Just use software of your choice.
JJ77
Sep 18, 2017Tutor
Sorry I was not clear. Safely is the question. When trying to backup PC get message that not safe to backup to internet destinations. When reading through easy share it looks like the basic selection would limit access to the saved data, but not completely sure this is the case. Since easyshare appears to be outside the household LAN, that is what the concern is.
- michaelkenwardSep 18, 2017Guru - Experienced User
- JJ77Sep 18, 2017Tutor
