junglesim
Jan 02, 2022Star
R7000 V1.0.11.126 -- Remote Management option has disappeared
Hello, I was just looking on the web GUI and noticed that under the Advanced Tab the 'Remote Management' item in the dropdown section on the left under 'Advanced Setup' is no longer there. I pre...
junglesim
Jan 03, 2022Star
Thanks Bill-D. Sorry I did not see your original post, the link was most appreciated. It is poor that someone from Netgear did not pick it up and explain the situation as it is pretty fundamental stuff.
Also, you mentioned 128. My router thinks 126 is the latest version so something is amiss and I don’t know what.
Bill-D
Jan 03, 2022Apprentice
Mine also doesn't indicate new FW versions. You need to go to "Downloads" to see if there's a newer version.
