junglesim
Jan 02, 2022Star
R7000 V1.0.11.126 -- Remote Management option has disappeared
Hello, I was just looking on the web GUI and noticed that under the Advanced Tab the 'Remote Management' item in the dropdown section on the left under 'Advanced Setup' is no longer there. I pre...
Bill-D
Jan 04, 2022Apprentice
As far as I see, the Nighthawk app is only usable locally on the same LAN as the R7000. Even though the app has a setting for "Anywhere Access", turning that on for "Out-Of-Home Controls" doesn't do anything.
Jan 04, 2022Guru - Experienced User
Yes access from anywhere should work if you enable it and are away from the home network.
- Bill-DJan 04, 2022Apprentice
It won't work for me. Am I missing something?
I noticed the free Netgear DDNS (provided by No-IP) has also been disabled in v128. This DDNS is what I previously used for the URL to access the Remote Management on both of my R7000s.
- junglesimJan 05, 2022Star
Anywhere access via the app works for me too. Not that it matters, but it may help, I noticed one slight change: last week when I connected localled or via anywhere when I wanted to change it to the other, it showed me both options, now it only shows me the alternative to how I am currently connected. So if I'm locally connected it'll give the option to connect via anywhere and vice-versa.
As for the DDNS, via noip.com, that seems to work the same for me as before. Just in case you missed it, 12 months ago or so, noip started to be more restrictive with their free hostnames by getting the user to confirm access once a month.
Please do note that on moving to 128 I have not made any changes that would affect these things, they just work for me.
- michaelkenwardJan 05, 2022Guru - Experienced User
junglesim wrote:
.... I noticed one slight change: last week when I connected localled or via anywhere when I wanted to change it to the other, it showed me both options, now it only shows me the alternative to how I am currently connected. So if I'm locally connected it'll give the option to connect via anywhere and vice-versa.
The prompted me to check my Android app.
The app connects "locally" when started.
To get to Anywhere, I hit the "cloud" icon at the top and get to the Your Products screen where I can choose Anywhere Access for stuff oi the Internet.
