Marynofear
Aug 02, 2022Aspirant
R7000 V1.0.11.136_10.2.120 port 520 is visible and closed (not stealth)
Doing a port scan on the R7000 with the latest 2 version of the firmware shows that port 520 is closed but not stealth. Port 520 is "efs" extended file name server. This might be the internal USB R...
- Aug 02, 2022
I was curious about this as well so I put my R7000 online with CM1200 modem.
I had v.134 loaded then also loaded v.136 and factory reset the router and setup from scratch.
Both report port 520 is Stealth'd:
GRC Port Authority Report created on UTC: 2022-08-02 at 22:00:12
Results from scan of ports: 0-1055
0 Ports Open
0 Ports Closed
1056 Ports Stealth
1056 Ports TestedALL PORTS tested were found to be: STEALTH.
TruStealth: PASSED - ALL tested ports were STEALTH,
- NO unsolicited packets were received,
- NO Ping reply (ICMP Echo) was received.----------------------------------------------------------------------
Tested both on a wired WIndows 10x PC and a Mac Book Pro 2018
uPnP test also passing as well.
Marynofear
Test on wired PC everything else disconnected.
Router setting everything disabled no RIP, no port forward, no Readyshare, no USB, no uPnP, No dynamic IP, no VPN, setup as router, no Static routes, no IPv6, no Bridge.
Total basic striped down.
After I found the port was not stealth, I tried most settings. I even was resetting the router. Still not stealth.
Aug 02, 2022Guru - Experienced User
Please post a screen capture of this result.
- MarynofearAug 02, 2022Aspirant
Well I cant se what use a screenshot can do. But anyway, here it is.
Found I was having Rip v1 enabled. Tried to disable RIP. But doing that exposed port 68 also as closed.
And also port 520 was still visible. And as I sometimes uses a Wi-Fi extender I will leave RIP enabled.
Reenabling it, makes port 68 stealth again.
I was wandering if it is possible to find some of the old firmware versions.
Last two firmware updates has this 'BUG'. But I know for sure, that the version prior to this, was 100% stealth.
Cant remember the version number.- FURRYe38Aug 02, 2022Guru - Experienced User
0 Ports Open
0 Ports Closed
1056 Ports Stealth
Will try and do a new factory reset. And then try again.
I will be back....... with an update.
