Marynofear
Aug 02, 2022Aspirant
R7000 V1.0.11.136_10.2.120 port 520 is visible and closed (not stealth)
Doing a port scan on the R7000 with the latest 2 version of the firmware shows that port 520 is closed but not stealth. Port 520 is "efs" extended file name server. This might be the internal USB R...
- Aug 02, 2022
I was curious about this as well so I put my R7000 online with CM1200 modem.
I had v.134 loaded then also loaded v.136 and factory reset the router and setup from scratch.
Both report port 520 is Stealth'd:
GRC Port Authority Report created on UTC: 2022-08-02 at 22:00:12
Results from scan of ports: 0-1055
0 Ports Open
0 Ports Closed
1056 Ports Stealth
1056 Ports TestedALL PORTS tested were found to be: STEALTH.
TruStealth: PASSED - ALL tested ports were STEALTH,
- NO unsolicited packets were received,
- NO Ping reply (ICMP Echo) was received.----------------------------------------------------------------------
Tested both on a wired WIndows 10x PC and a Mac Book Pro 2018
uPnP test also passing as well.
Marynofear
Well I cant se what use a screenshot can do. But anyway, here it is.
Found I was having Rip v1 enabled. Tried to disable RIP. But doing that exposed port 68 also as closed.
And also port 520 was still visible. And as I sometimes uses a Wi-Fi extender I will leave RIP enabled.
Reenabling it, makes port 68 stealth again.
I was wandering if it is possible to find some of the old firmware versions.
Last two firmware updates has this 'BUG'. But I know for sure, that the version prior to this, was 100% stealth.
Cant remember the version number.
Aug 02, 2022Guru - Experienced User
0 Ports Open
0 Ports Closed
1056 Ports Stealth
1056 Ports Tested
- MarynofearAug 02, 2022Aspirant
Will try and do a new factory reset. And then try again.
I will be back....... with an update. - MarynofearAug 04, 2022Aspirant
Seems factory reset, and manual setup did the trick. (did not load the backup config)
Thanks FURRYe38 - FURRYe38Aug 04, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
