Retired_Member
Dec 30, 2015R7000-V1.0.5.52_1.1.81.chk
I stumbled on this FW today and was wondering if anyone @ Netgear cared to comment on it. It's 12KB larger than the .48 Dated 12/21/2015 Has all the options that .48 had from what I can tell C...
- Retired_MemberDec 30, 2015
dBm levels should read -26 & -25
As a comparison to r8000 5g -38 2.4 -28
A 7.73GB file now tranfers in UNDER 2 minutes (mid 60's MBps) with r7000 ....R8000 takes over 2.5 minutes @ an average of 50MBps
mondenath
Dec 30, 2015Prodigy
netgear admin will post as new beta fw soon
Retired_Member
Dec 30, 2015The link in post 16 is working. What's the problem.
- mondenathDec 30, 2015Prodigy
No I said netgear admin will soon post as new beta fw. Nothing to be reported. If there are some changelogs which we can expect them to update .
new version has been released
check your router update
- mbob4568Dec 30, 2015Guide
Running it now and it added an Arlo tab for web cams. Seems to be ok.
- netwrksDec 31, 2015Master
I haven't run stock firmware in such a long time, but I may load this on of my 7000's. If anyone runs this FW in AP mode, can you check to see if NTP works?
- Retired_MemberDec 31, 2015
I'm sort of confused at the moment, so we have a beta firmware which is V1.0.5.52 which looks to be really good then now we have 1.0.6.28 which doesnt seem to be as good? XD I would have thought 1.0.6.28 would have included everything V1.0.5.52 had
- iRate3Jan 03, 2016Aspirant
Runs well. The added support for the Arlo cameras works great - means I can use the R7000 as the base station and ditch the other hardware that came with the cameras.
