Retired_Member
Dec 30, 2015R7000-V1.0.5.52_1.1.81.chk
I stumbled on this FW today and was wondering if anyone @ Netgear cared to comment on it. It's 12KB larger than the .48 Dated 12/21/2015 Has all the options that .48 had from what I can tell C...
- Retired_MemberDec 30, 2015
dBm levels should read -26 & -25
As a comparison to r8000 5g -38 2.4 -28
A 7.73GB file now tranfers in UNDER 2 minutes (mid 60's MBps) with r7000 ....R8000 takes over 2.5 minutes @ an average of 50MBps
Retired_Member
Dec 30, 2015new version has been released
check your router update
mbob4568
Dec 30, 2015Guide
Running it now and it added an Arlo tab for web cams. Seems to be ok.
- netwrksDec 31, 2015Master
I haven't run stock firmware in such a long time, but I may load this on of my 7000's. If anyone runs this FW in AP mode, can you check to see if NTP works?
- Retired_MemberDec 31, 2015
I'm sort of confused at the moment, so we have a beta firmware which is V1.0.5.52 which looks to be really good then now we have 1.0.6.28 which doesnt seem to be as good? XD I would have thought 1.0.6.28 would have included everything V1.0.5.52 had
- iRate3Jan 03, 2016Aspirant
Runs well. The added support for the Arlo cameras works great - means I can use the R7000 as the base station and ditch the other hardware that came with the cameras.
