winger13
Apr 12, 2017Guide
R7000 V1.0.7.10_1.2.3 and V1.0.7.12_1.2.5 OpenVPN cannot connect
My OpenVPN was working until I installed firmware V1.0.7.10_1.2.3 - unfortunately, I do not know what version I had before that. I tried resolving upgrading to firmware V1.0.7.12_1.2.5, but no succe...
- Apr 17, 2017
Just one note - someone had taken it that my OpenVPN is now up-and-running, but intermittently. In case anyone else have misunderstood me, let me clarify that this is not the case; rather, the hiccups I encountered was only during the initial Restore-to-Factory post above but have went away (without an explanation).
I am however going to test this new setup over the next week or two, and if all goes well, I will proceed by classifying this thread as "SOLVED". Until then, I will leave it as is.
winger13
Apr 13, 2017Guide
Kitsap
I run tests with neighborhood free Xfinity public Wi-Fi hotspots and any of my multiple mobile hotspot devices. I do not think it is possible to run any VPN tests of the R7000 VPN connected to it's Wi-Fi signal.
- KitsapApr 14, 2017Master
I am going to hold off updating my router firmware or OpenVPN client software for a couple of weeks. Some other home issues higher on my priority list.
I hesiate to suggest you reset the router to factory then reconfigure. It is a pain in the a$$. I still wonder why the V1.0.7.12_1.2.5 firmware is only available via direct download.
