winger13
Apr 12, 2017Guide
R7000 V1.0.7.10_1.2.3 and V1.0.7.12_1.2.5 OpenVPN cannot connect
My OpenVPN was working until I installed firmware V1.0.7.10_1.2.3 - unfortunately, I do not know what version I had before that. I tried resolving upgrading to firmware V1.0.7.12_1.2.5, but no succe...
- Apr 17, 2017
Just one note - someone had taken it that my OpenVPN is now up-and-running, but intermittently. In case anyone else have misunderstood me, let me clarify that this is not the case; rather, the hiccups I encountered was only during the initial Restore-to-Factory post above but have went away (without an explanation).
I am however going to test this new setup over the next week or two, and if all goes well, I will proceed by classifying this thread as "SOLVED". Until then, I will leave it as is.
winger13
Apr 14, 2017Guide
Kitsap
So, if I choose to factory reset, what version of the firmware should I upgrade to? I sure won't want the factory firmware from 2 yrs ago.
And what version of the OpenVPN client should I use?
That said, would another option be to downgrade the firmware directr to see if that works? As I mentioned on the OP, I believe the firmware update to V1.0.7.10.... screwed this up in the first place. Where would i get older firmwares?
Does Netgear support frequent these forums? Wondering if they do, if they can come in from a customer support standpoint. Should I try calling their support or they would simply say my indoor is out of warranty period and cannot help?
Kitsap
Apr 14, 2017Master
Yes, Netgear employees or associates routinely reply in these forums. @ElaineM in particular.
I would recommend the https://swupdate.openvpn.org/community/releases/openvpn-install-2.3.14-I601-x86_64.exe client software and the version of the R7000 firmware just before V1.0.7.10_1.2.3. V1.0.7.6 was the previous version. You can go to this link, at the bottom of the section of current versions there is a dropdown labeled previous versions. https://www.netgear.com/support/product/r7000.aspx#download
These two items worked well for me over an extended period of time. I did not even consider updating until the security issues surfaced with regard to the Netgear firmware several months ago.
