winger13
Apr 12, 2017Guide
R7000 V1.0.7.10_1.2.3 and V1.0.7.12_1.2.5 OpenVPN cannot connect
My OpenVPN was working until I installed firmware V1.0.7.10_1.2.3 - unfortunately, I do not know what version I had before that. I tried resolving upgrading to firmware V1.0.7.12_1.2.5, but no succe...
- Apr 17, 2017
Just one note - someone had taken it that my OpenVPN is now up-and-running, but intermittently. In case anyone else have misunderstood me, let me clarify that this is not the case; rather, the hiccups I encountered was only during the initial Restore-to-Factory post above but have went away (without an explanation).
I am however going to test this new setup over the next week or two, and if all goes well, I will proceed by classifying this thread as "SOLVED". Until then, I will leave it as is.
winger13
Apr 14, 2017Guide
Kitsap
By 'resetting the router to factory' you referring to what I posted above?
1. Click ADVANCED > Administration > Backup Settings.
2. Click Erase.
2. Click Erase.
Kitsap
Apr 15, 2017Master
No. Download the manual here: http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf and go to page 192 to follow the procedure to return the router to factory settings.
