Potatowizard
Apr 17, 2017Tutor
R7000 V1.0.7.12_1.2.5 firmware update
Hello So i'm going to get into my issues since this update. For reference my Mbps is 120/15 1) I can no longer multitask. If i'm downloading a file (350mb for example) i can no longer stream ...
- Apr 17, 2017
Check if dynamic QoS is enabled.
shamarin
Apr 17, 2017Virtuoso
- PotatowizardApr 24, 2017Tutor
shamarin wrote:Check if dynamic QoS is enabled.
It was not. Thank you for your reply. Had to tweak quite a bit of stuff to get my network working again..Anyway, thanks again.
