Potatowizard
Apr 17, 2017Tutor
R7000 V1.0.7.12_1.2.5 firmware update
Hello So i'm going to get into my issues since this update. For reference my Mbps is 120/15 1) I can no longer multitask. If i'm downloading a file (350mb for example) i can no longer stream ...
- Apr 17, 2017
Check if dynamic QoS is enabled.
Diggie3
Apr 22, 2017Luminary
I still can't generate a new VPN key with this new firmware. This is amazingly bad. How can you have a VPN feature that's impossible to secure because you can never re-key the lock?
I really hope router review sites start taking points off for this problem. In fact, I'm going to start reaching out to the editors myself. Absolutely ridiculous.
