Potatowizard
Apr 17, 2017Tutor
R7000 V1.0.7.12_1.2.5 firmware update
Hello So i'm going to get into my issues since this update. For reference my Mbps is 120/15 1) I can no longer multitask. If i'm downloading a file (350mb for example) i can no longer stream ...
- Apr 17, 2017
Check if dynamic QoS is enabled.
Kitsap
Apr 18, 2017Master
T
Potatowizard wrote:Hello
The way attached devices use to show up was by Wired devices, listed with names. Then 2.4Ghz wireless devices, then 5.0Ghz devices. Now? It's all mixed together. Wired, wireless, wired wired, wireless wireless, wired, wireless, wired. Seriously, why?
With the new list format for attached devices after the firmware update you can click on each of the headers and sort up or down. A great tool for people who needed some flexibility with respect to the old display format. Click on Connection Type once or twice and you can duplicate the old format.
Potatowizard
Apr 24, 2017Tutor
Kitsap wrote:T
Thanks -- This was really unclear from how the list looks. Thanks for your reply. Got the hang of it now!
